Ir para o conteúdo principal
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 Perguntas Visualizar todos
My ps4 control wont charge, I dont see yellow light
I controller was working a day ago, my controller analog stick is broken but I'd fixed it, but on the next day it won’t charge anymore.
My controller issue is: Broken or damaged battery, is the damaged battery is the cause of not charging?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi!
Yes it could be your battery, but it also could be the charge/LED board.
When you put the USB cable in, does the orange light flash? If yes, battery is probably bad. If no, it could be the battery or charge/LED board.
Esta resposta foi útil?
Pontuação 1
4 comentários:
My controller works fine 2 days ago.
What do you mean Charge/LED board?
Please help me, so that i can save money.
Thank you
por
Example: DualShock 4 Charging Port Replacement
Check the board, is the USB port still good? Does it look fine? Cable connected as it should (to the motherboard)? And do you get any type of light, or is it just dead all the time (even with trying to charge) ?
por
You mean The Back Part of Controller The that has LED that connected right on the battery?
por
Yes that’s what I meant :)
por
is this the board or the usb port you talking about??
Pontuação 0
4 comentários:
Yes that is the one I meant. Is it still good? Perhaps that one needs to be replaced.
por
So do i need to replace the LED or the white power connector thingy?
por
After running a few test, my controller LED light up in green but no so bright but only the LED and the rest are not working
por
When I bought my ps4 and start playing a few days later my controller was down on battery so I started to plug in the charger but couldn't see the yellow charging light.
por
Adicionar a sua resposta
Chloyd será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 51
Duração total: 1,561
