Why monitor displays a lot of lines on screen?
After I startup my iMac there's a lot of lines on the screen. Now I am unable to see what's on the screen.
Could it bethe monitor faulty?
Esta é uma boa pergunta?
Please, connect your iMac on an external monitor and tell us if the video output is normal. It's the first step to troubleshoot a screen issue. The issue could be related to a bad GPU (graphic processor unit) located on the logic board or a screen internal component such as LVDS cable or the LCD panel. You can exclude the inverter and backlight failure if your screen still has lightning.
Esta resposta foi útil?
Your answer was so much better than mine that I deleted mine. one up
Hi lemerise,
Thank you for the insightful tips.
How do you connect to an external monitor?
Look at this first then tell us what kind of lines, in what direction, what color and anything else you think we may need.
Hi lemerise,
Check on here http://support.apple.com/en-us/HT2567 and here http://fairerplatform.com/2010/06/how-to... as well
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,507
