Wide white lines showing up on display
We have a MacBook Pro A1226 that I had to replace the monitor on about a month ago. I followed the instructions provided on this site and everything went perfectly and the display has worked flawlessly until now.
Now, we have a puzzling problem. The screen now shows a wide white line (approx 2" wide) accross the top of the screen and another running down the middle. The computer displays fine on an external monitor. The puzzling part is you can take your index finger and thumb and "pinch" the middle of the right side of the clamshell top and the problem disapears. The aluminum case shows no warping or damage of any kind. We have fixed the problem temporarily by placing a large paper clamp on the side of the display which makes the display work perfectly.
Does anyone have any ideas as to what might be going on?
Thanks in advance for any help!
Esta é uma boa pergunta?
1 comentário
Dear Bac,
Did you succeed in fixing the display? I have a similar problem and I am very interested in the solution.
Thanks in advance!
Kind regards,
Guido
por iFatamorgana
