Ir para o conteúdo principal
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
Kernel panic when brightness is turned all the way up
So I saw a lot of people without any answers having the same problem: I have a 1.6GHz MacBook Air A1237, and apparently it kernel panics with “Invalid Backlight Duty Cycle” in the log whenever I turn the brightness all the way up.
I was wondering if maybe the display wasn’t the right one, maybe one for the late 2008 put in a early 2008 enclosure? And what could I do to fix it?
I already know of the “Downgrade the kext” way but I’d rather fix it completely rather than hack it, thanks for the help!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What is the macOS you are running?
por
@danj 10.5, but it happens on 10.6 and 10.7 too
por
Adicionar um comentário
1 resposta
Pergunta mais útil
“A man goes to the doctor, says, “Doc, it hurt when I do this”. Doc says, “Don’t do that”.
Henny Youngman
Esta resposta foi útil?
Pontuação 2
10 comentários:
Need to stick with OS-X 10.5.2 Leopard on this series.
Apple didn't do a very good job in its test suite for newer OS-X releases. This is a OS issue not a hardware issue.
por
@danj but how does it make sense? Why would it do this? When you bought it when it came out it didn't do this before that's what I don't understand
And how would the invalid backlight duty cycle appear?
por
@nar001 - The issue is the driver (kext) code. Apple upgraded the graphics services quite a few times overtime jumping from Intel to NVIDIA and then back to Intel. This driver needs to identify which graphics services the given system has so the proper code is used.
MacBookAir1,1 - Intel Graphics Media Accelerator (GMA) X3100
> MacBookAir2,1 - NVIDIA GeForce 9400M
> MacBookAir3,2 - NVIDIA GeForce 320M
MacBookAir4.2 - Intel HD Graphics 3000
MacBookAir5,2 - Intel HD Graphics 4000
MacBookAir6,2 - Intel HD Graphics 5000
MacBookAir7,2 - Intel HD Graphics 6000
The issue here is the snippet of code needed for the NVIDIA chips has a problem within the newer generations of OX-X/macOS!
Looking back in time .... We know Apple and NVIDIA broke its relationship (Lawsuit) so the needed fixes in the code couldn't be applied as they just weren't talking to each other! Even today they still aren't talking!
por
@danj But does that mean ALL original macbook air have the same problem? How were they explaining that to people who bought a 2.5k laptop and had trouble with the backlight later?
por
The issue you are facing is exclusive to the NVIDIA GeForce 9400M & NVIDIA GeForce 320M models.
por
Exibir mais 5 comentários
Adicionar a sua resposta
Nar001 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 264
