Ir para o conteúdo principal
The M3D Micro is an affordable 3D printer that comes in a small compact size.
How do I get my computer to recognize the device?
Recently, my printer started acting weird and saying that it couldn’t be recognized by my computer. I don’t know what happened, but when I plug in both the printer cable and power cable, the fan turns on, but then the error message displays in the bottom right corner. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @themontanaman ,
Have you tried a different printer cable or USB port on the computer?
What OS is installed in the computer, Win, Mac, Linux?
If Win (which one Win10, 8.1, 7 etc) I may be able to help further, if the others then I don't know.
por
Adicionar um comentário
1 resposta
If you’re trying to use your printer and run into problems, here are some steps for common printer problems to try to get things working again.
https://support.microsoft.com/en-hk/help...
Please do keep updating, thank you!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rylen Robertson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 311
