Ir para o conteúdo principal
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
Power button does nothing unless held while unplugged
My IMac does not respond when I press the power button. The only way I get anything is when I hold the power button while plugging it in then pressing it again. Yet, the fan spins but the second diagnostic led does not light nor does the mac boot. Tried clearing SMC but nothing.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Has this been fixed?
por
Adicionar um comentário
1 resposta
It appears to be a power supply issue. Could you try replacing the power supply?
Imagem de iMac Intel 27" Retina 5K Display Power Supply
Guia
iMac Intel 27" Retina 5K Display Power Supply Replacement
Nível de dificuldade:
Moderado
1 - 2 hours
Imagem de iMac Intel 27" EMC 2639
Guia
How to find and read the Diagnostic LEDs
Difícil
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have a 2007 MacBook Pro that had the same issue, and I discovered it was because it had no battery, and a low wattage power supply.
por
Adicionar a sua resposta
Bradley Crawford será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Ao todo: 151
