Ir para o conteúdo principal
Guias de reparo e suporte para a linha de laptops da série Aspire da Acer, voltada para uso doméstico casual e comercial.
HOW do remove BIOS password
how can slove my laptop bois password…
ACER Aspire3
model=N19H1
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Enter the wrong password and add the code here
por Compartilhar
Adicionar um comentário
1 resposta
Not sure if it is stored in CMOS flash chip or in the ram, that can be reset. I don’t have the machine, so cannot confirm it myself.
If it can be cleared, yuou would need to open up the laptop, and remove the main battery, and the CMOS battery from the system.
https://www.youtube.com/watch?v=HrDRDkun... was a teardown of a related system.
Imagem
I have circled the connectors for the main and CMOS batteries. It can take a while for the circuits to forget, so it would likely take a few minutes before reconnecting it. You will need to reprogram the clock and likely the settings in the BIOS.
It could also be there is a OS password, that might need to be reset as well.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brothers computer care Das será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,475
