I had the same problem, i saw this forum, i also tried with oil and boiling water, it didn't help, then i saw a german disassembling the Circulation Pump, i disassembled the machine, i removed the pump, i disassembled the pump, one of the sectors that is responsible for changing between the good water and the used one was with residues, which didn't seem normal to me, i cleaned everything, lubricated it, assembled it inside the machine, it started working, it wasn't easy at all.
It only worked once and again the same F78, again I disassembled the machine, before disassembling the pump, I noticed that there were bits of grease(or bits of anything) in the used water reservoir, I assembled the machine, heated the water, poured several liters of boiling water into the machine, waited a few minutes, unplugged it, plugged it back in and it started, I put it in the most powerful mode at 70ºC to see if that grease (or bits of anything) would come out of the reservoir, for now it works.
One of the things i was told to do when i bought the machine was to put the strongest mode with empty machine to work to clean the machine some times, I never did this, hence the possible malfunction.
The video of the German dismantling the pomp is here if anyone wants it.
Miele Geschirrspüler Umwälzpumpe zerlegen + Wasserweiche einstellen + F78 F79
https://youtu.be/yiuzdwnSaFM
7 comentários
Does it have any sensors to detect the water level?
por Jesse Hooton
Hi @asaxena ,
Are the spray arms turning?
Place both the arms in a known position and start the machine. When it has filled with water and"started to wash" open the door and check the position of the spray arms to see if they have moved at all.
If not then the pump is not operating.
Can you hear if the the pump motor is working or is it just humming?
por jayeff
@hootonberg Many thanks for looking at this. I don't know of any. I think the answer is no.
@jayeff Many thanks for your suggestion. Here is what I just did:
- filled up about 1 litre of water in the dishwasher, and put the arms in a known position. Turned it on, and heard the usual sounds that indicate water draining.
- about a minute later, I opened up the dishwasher mid-cycle. Initial water had all drained out. Shut it back again and let the cycle continue.
- About 2-3 minutes after this the dishwasher beeped to indicate the error F78. Opened it up - the dishwasher is now filled with water up to slightly below the filter handle.
- The arms were NOT in the position I left them in.
Looking forward to hear more. Thanks once again!
por Abhishek Saxena
I have the same issue and now I have taken apart the dishwasher och removed the pump. The axle where the impeller sits is pretty sluggish to rotate on my pump. Does anyone know if this is normal or if the rotation should be really easy (like a normal ball bearing easy)? I'm thinking there could be an o-ring in place as a seal which, in that case, would make it more sluggish.
por Christoffer Lindquist
I wish I'd never bought this bloody dishwasher constant problems
por ben simons
Exibir mais 2 comentários
