Ir para o conteúdo principal
O pregador Dewalt modelo DW66C-1 é um pregador pneumático de bobina para revestimento de 15 graus fabricado pela Dewalt (estilizada como DEWALT).
rapid fire not working
dewalt siding nailer RAPID FASTENER OPERATION: doesn’t work? what parts are needed ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Does the question poster mean that if the trigger is held, and the nose is bumped repeatedly to a workpiece, it only drives the first nail? This activity is called "Bump mode". The tool has a two-position trigger switch knob on one side of the trigger. The knob is set to point to sequential fire (indicated by a single nail) or bump fire (indicated by three nails) embossed on the housing.
If the selection knob is properly set and selects both modes, and the nailer fires correctly only in sequential mode, the selection knob mechanism should be inspected or disassembled for improper assembly or excess wear.
Alternately, if the nail feed mechanism fails to feed the next nail each time, the nailer will keep firing "blank" shots without driving the second and following nails.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Fernando Gonzalez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 1,029
