Ir para o conteúdo principal
Um laptop 2 em 1 com tela tátil, fabricado em 2017 pela Acer, modelo N16W1.
New battery not working
I put a new battery in this computer from ifixit. Now the battery meter shows it's at 255%. Also the computer shuts off after 2 minutes. What can i do to fix this
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You can try software:
https://windowsreport.com/laptop-battery...
Or do it yourself:
To re-calibrate your laptop's battery, you can follow the steps below:
Important: Re-calibrating your battery may take several hours depending upon your system configuration as well as the age and life of your battery.
1. Turn your laptop Off. Then plug in your AC adapter.
2. Let the battery fully charge, until the battery LED turns Off.
3. Now, turn On the laptop and then press F8 key repeatedly when the first logo screen comes up.
4. In the "Windows Advanced Startup" menu, go to "Safe Mode" and then press the "ENTER" key.
5. Unplug the unit and let the computer run on battery until it shuts down.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
andy starback será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 731
