Steering column swap 88 to 89
Can the steering column from an 89 be swapped into the 88?
Esta é uma boa pergunta?
Check with a junkyard--they have a manual showing where parts can be used from one vehicle to another.
Esta resposta foi útil?
I didn't know that thanks
What model will fit a 1996chevytruck steering column
But I said 1996
By comparing some numbers the 88-94 Chevy 1500 2500 Suburban, 2wd or 4x4 GMC Sierra 1500 2500 will all work. Verified by Hollander Interchange that they do fit. Hope this helps....good luck.
Can anyone tell me what steering columns are compatible with a 1991 GMC C 1500 sierra
Hollander huh
Ok what years are compatible with a 1991 GMC Sierra
Just in case this w help someone.the 1998 gmc sierra steering column is by itself no others fit
What steering column will match up with a 1989 Dodge 4/4
what other year steering columns will fit in my 95 silverado 1500 automatiac
I'd like to know if a 1997 z71 steering column can be swapped with a 1998 z71 steering column???
1990 Chevy suburban 4x4 350 700 r4 tans will a GMC steering column swap work
Will a Steering column off a 1995 Chevy Silverado 1500 fit on a 1995 GMC Sierra 1500 ?? Someone Please Let me know ❗
yes it will i put one in a 95 gmc i owned swapped right over
Would someone please tell me what will swap out with a 1992 chevy steering column
88-94 GMC/Chevy full size trucks or vans,Tahoe's/Yukon's!!
Can u swap a steering column from a 91 Chevy 1500 automatic with a 92 Chevy 1500 5 speed
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Duração total: 24,938
2 comentários
This is a K1500 chevy pickup.
por Steve
Yes it is thank you
por george moore
