Ir para o conteúdo principal
Modelo A1347 com processador Core 2 Duo de 2,4 ou 2,66 GHz.
Check if SMC was reset
I want to do an SMC reset and did so by powering off, disconnecting cable, holding pwr button, plugging in, powering on. But is there a way to verify i reset the SMC successfully? Resetting PRAM/NVRAM is clear because you hear 2 chimes
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I'm not sure I follow what you are looking for.
por Compartilhar
When you do the SMC reset, is there a way to know you did it properly? Like, sound cues, reset date/time or something like that. I want to know if i did it properly
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
A SMC reset null’s the values it holds so there is no means to tell for sure. What is the problem you think an SMC reset will alter?
Esta resposta foi útil?
Pontuação 1
1 comentário:
It was high temps and weird fan controlling. But i think it did reset because the volume changed from max to 50%
por Compartilhar
Adicionar a sua resposta
Max Tech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 530
