keeps saying code 08 but it doesn't have a reset button
Ok I bought a colman saluspa hot tub and it keeps saying code 08 but it doesn't have a reset button on the pump so is there anyway I can reset without that button?
Esta é uma boa pergunta?
A search pulled up that the code requires a thermal reset. This video shows the power switch being used, along with the GFI test button on the pump cord, not on the pump itself. Here's the link:
Esta resposta foi útil?
There is a reser button, it just depends on the model number where its located. Refer to the owners manual for your unit. It is available online in a pdf ,if you no longer have it.
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 3,934
Hi ,
What is the model number of the spa?
por jayeff
Tried fix but still doesn't work. I have a similar model without a reset button on the side. Every video I've looked at shows only models with reset buttons. What's up?
por Tibor Ouyang
@tiborouyang
What is the model number of your hot tub?
por jayeff
model S100104
por STEPHEN BRONN , QAFP
