Ir para o conteúdo principal
Replace HDD for HDD Box Buffalo MiniStation 2,5" USB 2.0?
Please do me a favor to guide me how to replace HDD on HDD Box External Buffalo MiniStation (2,5" - USB 2.0). I 'd like to replace the HDD inside that box. This is the link of product, it's quite hard to open (no screws +_+):
http://www.buffalo-technology.com/produc...
Pls help me ASAP. ^^
Thank you so much in advance
I love your site ^^
Esta é uma boa pergunta?
Pontuação 2
4 comentários
Please, anyone? +_+
por
I need helpppppppp +_+
por
This question was migrated from http://meta.ifixit.com/Answers.
por
I still need your help! +_+
After few weeks, I'm still waiting for a solution! +_+
por
Adicionar um comentário
5 respostas
Solução escolhida
I can find no information on dis-assembly of this unit. Looking at the photo of the unit it appears there is a seam going around it. You might try using a Spudger to go around that seam to see if that gives you access to the drive for replacement. Good luck.
Metal Spudger Set
Esta resposta foi útil?
Pontuação 4
2 comentários:
Thanks for your answer,
I think so, but actually I'm afraid my outside box will be damaged.
Should I take some photos close up to all of my device's sides and show to you to get an advice?
Have a nice day! ^^
por
You could call the maker and ask for service. Ask them how to open the device. As I said I could find no information on procedures for replacing the drive--I think they may want you to pay them to do it. There is always risk in trying a procedure like opening a case--you have to decide if its worth the risk to you.
por
It has a two year warranty.
Pontuação 3
I made a guide for this, hope it helps.
Disassembling Buffalo MiniStation External Hard Drive (Thunderbolt & USB 3)
Pontuação 1
Thanks guys, Actually, I bought this device in Korea and there is no official reseller or global warranty in Vietnam for it! +_+ So, I will leave this topic open and welcome all the ideas coming before I break it up! ^^
Pontuação 0
just put an ATM card inside the edge, then lift it up slowly, starting from the long edge!
Pontuação 0
Adicionar a sua resposta
quangtrungdesigner será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 5,498
