Ir para o conteúdo principal
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
20 Perguntas Visualizar todos
Green light will come on top screen flickers and turns off?
I try to turn the DS on but the green light will go on momentarily and then the top screen flickers white and quickly turns off again. I changed the fuses thinking it was a fuse problem but the same problem persists. Help is much appreciated. Could it be the screens? oh by the way the cable that connects the top to the bottom was also replaced to a new one since the old one had been broken.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Check the lower LCD backlight cable and connection. It is under the large ribbon cable for the lower screen. You will need to unhook that cable. It is the small cable on the right under the larger video cable. The other small one is for the digitizer. Clean off any corrosion on the cable connector and cable. Make sure the cable is seated properly in the socket/connector and that the little brown retainer clip is pushed in holding the cable in. If the little brown retaining clip is missing you will need to replace it before it will work (you can find them on eBay). Reattach the large video cable. The thicker brown part of the cable should be just behind and parallel with the white line on the logic board. Make sure the flap retaining that cable in the socket is down evenly. Sometimes it wants to bow out in the center. Hold the battery firmly against the terminals. Press the power button. If the backlight for the lower screen is good the lower screen should at least flash if not stay on. If it doesn't replace the lower screen.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Ok thank you. If you can please give me a link or how do I look for the brown clip? I also wanted to replace the bottom lcd so if you know where to find one I would appreciate it. On ebay all I can find is the replacement bottom screen for the lite system.
por
Is yours missing the brown clip? What country are you in so I can better direct you to a good place for the LCD?
por
yes it is missing the clip and the one of the smaller ribbons is broken off. I'm in USA.
por
do you know where I can get the brown clips or how do I look for them?
por
Adicionar a sua resposta
fernanda será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,613
