Ir para o conteúdo principal
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
20 Perguntas Visualizar todos
Where can I purchase a replacement fan
one of my fans is making a grinding noise. I see there is a guide on here how to replace it but where can i get the fans.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
https://www.amazon.com/Cooling-GTX1060-R...
https://www.aliexpress.com/i/33012273436...
Here are some links. Before you proceed though, you should make sure it’s not just built-up dust blocking the fan.
It will potentially save you time, money and effort.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for this. I will double check the dust but i have cleaned out using air.
por
No problem Alex :). It could also be hitting a wire, hence the noise. Make sure everything is properly into place and that wires don't overlap where they don't need to.
por
Adicionar a sua resposta
Alex será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 4,239
