Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
20 Perguntas Visualizar todos
Horizontal lines, and black screen with sound
Recently my Switches screen started acting up out of nowhere. When I power it on or wake it the screen is covered in multicolored horizontal lines with a sort of grid pattern, after about 1-3 seconds the screen will go black with backlighting still present. The digitizer seems to work perfectly as well, and the Switch functions normally when docked. This problem seems to have appeared out of the blue with no forewarning. It seems to have occurred in the span of about 5-10 minutes. I plugged my switch into the charger and left the room for a moment, upon returning the screen was completely covered in the aforementioned lines. I’m not sure if it’s an issue with the lcd or possibly an issue with the motherboard. I opened the switch up and there doesn’t seem to be any issue with the ribbon cables or connection. Any help would be very very much appreciated.
Esta é uma boa pergunta?
Pontuação 3
4 comentários
I have same issue on my switch lite
por
Hello did you solve your problem with the switch screen? I'm having the same issue with my switch lite and it came out if nowhere.
por
Same just happened to me yesterday without me dropping it or anything happened out of the blue just like that
por
I have this exact same problem, it came out of nowhere while someone was playing on it today. The screen also seems pixelated in some way, I'm gonna try to do something with the LCD flex cable.
por
Adicionar um comentário
4 respostas
Solução escolhida
I reseated the LCD flex cable for the display carefully and that seemed to fix the problem for me. It only occured when I unplugged the display cable from a previous repair.
If reseating the display connector does not help the display most likely needs to be replaced:
Nintendo Switch LCD Replacement
Nintendo Switch LCD
Imagem de Replace a damaged or malfunctioning LCD display panel in a Nintendo Switch.
Produto
Nintendo Switch LCD
$39.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks for the advice I’ll give it a shot, not sure how the cable could have been dislodged, possibly overheating?
por
The cable shouldn't go loose by itself as it is locked into place with a zif-flap connector. Worst case it would be the screen going faulty and needing to be replaced.
por
my switch lite have that issue. when some ants get inside of my switch lite.i think the ants the to eat the ribbon. thats why im getting that issue.
Pontuação 0
All i know, i lived in jamaica and my switch have lines, and i don't know how to fix it, All i gotta say is goodbye switch, my aunt gave me this nintendo from another country, bye nintendo, bye youtube, bye fortnite😞
Pontuação 0
This problem happened to me suddenly mid gaming and seems to get worse the warmer the console gets. I wonder how could this happen.
Pontuação 0
Adicionar a sua resposta
Laurence Zeffler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 134
Últimos 30 dias: 610
Duração total: 36,696
