Ir para o conteúdo principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Perguntas Visualizar todos
Slow and Laggy 2011 Mac Mini
My Mac Mini is quite slow and laggy. I have to experience a lot of spin wheels even for the simplest of tasks such as right-clicking to copy or paste something.
  • macOS 10.13.6
  • 2.3 GHz Intel Core i5
  • 5 GB 1333 MHz DDR3
  • Intel HD Graphics 3000 384 MB
I currently have 4 GB and 1 GB memory cards, however even with 2 x 4 GB cards I still experience the same problems.
It cannot handle more than 3 basic apps running at the same time. I usually have Safari, Mail, and the Music apps running all the time but if I decide to open anything else e.g. Photos, it becomes extremely slow forcing me to close one of the apps.
It also struggles with more than 6-7 Safari tabs depending on the webpages.
I often listen to a music playlist on YouTube and maybe after 15-17 songs, I have to close the tab and open a new one. It warns me about using significant energy and if I ignore it the device runs slow.
I am only using two extensions for Safari, Grammarly and AdGuard.
I am only performing the most basics of tasks on this device and it struggles to keep up with it.
I don’t want to buy another Mac, new or used. I am sure there is something that can be done to fix this issue.
I have these apps installed on my Mac which I believe are quite basic apps.
AdGuard for Safari, Android File Transfer, App Store, Automator, BitTorrent, Calculator, Calendar, Chess, Contacts, DaisyDisk, Dashboard, Dictionary, DVD Player, Express VPN, FaceTime, Font Book, GarageBand, Chrome, Grammarly, iBooks, Image Capture, iMovie, iMovie 9.0.8, Install OS X El Capitan, iPhoto, iTunes, Launchpad, Mail, Maps, Messages, Microsoft Silverlight, Mission Control, Notes, Numbers, Pages, Photo Booth, Photos, Preview, QuickTime Player, Reminders, Safari, Siri, Stickies, System Preferences, TextEdit, Time Machine, VLC,
Thank you for reading.
Cheers!
Esta é uma boa pergunta?
Pontuação 0
3 comentários
What is your drive and its size? How full is it?
Also lets try running the onboard diagnostics restart your system and press the D key
Reference: Mac startup key combinations Let us know what you get for an error.
por
Thank you for your response.
500 GB SATA Disk, 250 GB used.
I ran the test and it returned with no errors.
por
I can constantly hear the device doing something. Definitely not the fan, maybe the drive?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
The real issue is the HDD over time gets fragmented. Getting a defragmentation app to undo the fragmentation or backup the drive fully and reformat it will also work.
Replacing your HDD with SSD is also a good direction or what I would do is add the SSD! Installing Mac mini Mid 2011 Dual Hard Drive Kit That way I can make the SSD be the boot drive with my apps and leave my stuff on the HDD. That way you don’t need as large a drive! A 250 GB would be more than enough for most people!
Esta resposta foi útil?
Pontuação 1
Oh Man! Just replace with the SDD and you are good to go.
Pontuação 0
1 comentário:
Yes, I might just do that. I will upgrade the size too.
por
Adicionar a sua resposta
Abhishek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 11
Duração total: 595
