Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Will a 2017 screen fit a 2014 27” iMac 5k?
I have an iMac 5k with image retention problems. A thread I read on the subject seems to show all the screens have this problem until 2017. Rather than get a screen that will go bad again, I wanted to put a 2017 screen in. Pictures show their ports look identical, but I want to be sure before I put $400 into one. Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly, Apple created their own T-CON logic for the first generation of 5K iMac’s (2014). Review Step 6 in the iMac Intel 27" Retina 5K Display Teardown The newer displays use a different logic as such the interface connection to the logic board is not the same.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mark2000 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 875
