Ir para o conteúdo principal
Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
100 Perguntas Visualizar todos
MacBook Pro 2018 not charging because I spilled a wine on it
Hello
I spilled a little wine on my MacBook and it immediately stopped charging although it is working fine. I see notification that says says it has been disabled because a device is using too much power…
I have tried resting the SMC but that didn’t work. And then saw this link that could fix the error but then my Mac is off.
Is there other this I could try since the Mac is now off?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The notification is telling you. “I am not letting any power into my charging circuit because it has a faulty component in it” This is protecting your Mac. The liquid has obviously damaged a charging circuit component. You will need to source a reputable repairer to replace the faulty component. It is no good going to Apple as they will tell you need to purchase another Mac.
Esta resposta foi útil?
Pontuação 4
3 comentários:
Hi! thanks for your reply. I opened the system and I saw that the connector from the port to the motherboard got burnt. Do you think this is repairable and how much it might cost?
por
@dongido, can you post a picture of the burnt connector?
Adicionar imagens a uma pergunta já existente
por
@dadibrokeit
It's been a while and I lost the pictures already. But here is the story of how it ended.
The first repairer charged me almost the price for a new one so I took it to another repairer who charged really fair.
He said he would replace the board connected to the charging ports. But he later ended up rendering the Mac useless as the replacement part is taking months to get to him.
I finally took the Mac from him because it took him more than 4 months and the part is still on the way.
Then I took it to another repairer who discovered that the last repairer has rendered the Mac useless. After back and forth, I gave up on the Mac.
por
I’d contact The Rossman Group on this one.
https://www.rossmanngroup.com
Pontuação 0
Adicionar a sua resposta
gideon onwuka será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 281
