Ir para o conteúdo principal
Modelo M5343 / processador G3 de 333 ou 400 MHz
How to remove the battery?
How does one go about removing the battery? there seems to be a button on it but pushing it has no effect other than making the green lights go on, I've seen a great how-to on other computers and was hoping there was one for this old lady as-well.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
On the front edge of the case is a lever. Pull the lever and slide out the battery. The lever on the other side is for removing your optical drive although some people put a battery in both sides for more battery time. URL for a drawing is http://forums.macrumors.com/showthread.p... Go to number 5. Ralph
URL for this unit PowerBook G3 Lombard
Esta resposta foi útil?
Pontuação 3
2 comentários:
The green lights indicate charge level of the battery. Ralph
por
Thanks, that did it.
por
Adicionar a sua resposta
Bill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 38
Ao todo: 4,032
