Ir para o conteúdo principal
Repair and disassembly instructions for Jura Impressa F50 fully automatic coffee machines
9 Perguntas Visualizar todos
Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Imagem de Jura Capresso IMPRESSA J5
Guia
Jura Capresso IMPRESSA J5 Drainage Valve disassembly
Nível de dificuldade:
Fácil
5 - 10 minutes
Imagem de Jura Impressa C E F Modelle Heater
Guia
Jura Heater Replacement
Moderada
1 hour
Guia
Remove Jura Brew unit
Moderada
9 - 15 minutes
Esta resposta foi útil?
Pontuação 2
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
Pontuação 0
1 comentário:
It's much cheaper just to replace the gasket or the valve of the tank.
por
Adicionar a sua resposta
Colin Brown será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 51
Duração total: 1,908
