Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Esta é uma boa pergunta?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Guia
Nível de dificuldade:
Fácil
5 - 10 minutes
Guia
Moderada
1 hour
Guia
Moderada
9 - 15 minutes
Esta resposta foi útil?
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
It's much cheaper just to replace the gasket or the valve of the tank.
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 51
Duração total: 1,908
