Ir para o conteúdo principal
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
29 Perguntas Visualizar todos
How do I change the oxygen sensor?
can you help me because i want to change the oxigen filter but i need some help with that can you put some pictures of the way to do it tanks for you help and the service online
How do I change the oxygen filter?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
justin, which one is the oxygen filter that you are referring to?
por
i think looking at his other post he means oxygen sensor..?
por
Adicionar um comentário
1 resposta
Solução escolhida
justin, if you are talking about the O2 sensor like my colleague pollytintop pointed out, there are two. One in front of the catalytic converter and one after. There are some really good instructions on here. If you are really ambitious, here is the part of the manual that deals with the exhaust and O2 sensor parts. Hope this will help. Good Luck
Esta resposta foi útil?
Pontuação 3
3 comentários:
sorry is the oxigen sensor the one on tap
por
Its okay my friends helped me clarify it. Hope the manuals are going to help you...
por
Glad to hear you got it fixed. Just copy your other question on here, So we know it worked. GREAT JOB....;-)
por
Adicionar a sua resposta
justin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5,519
