Ir para o conteúdo principal
The Motorola Moto Z3 Play was released in June of 2018. It has a 6 inch screen and a non-removable Li-Ion 3000 mAh battery. Its rear camera is 12MP and its front camera is 8MP. Model number XT1929-3, XT1929-4 and XT1929-8. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
13 Perguntas Visualizar todos
Best way to get water out of the power button?
I dropped my Z3 (in an otterbox) in some water yesterday and it seemed to be doing fine for a few hours, but then it started acting as if the power button was being constantly held down, which led me to believe that there was water closing the circuit that the button usually would. Is there any good way to get the water/moisture out from near the power button without completely taking the phone apart? I’ve tried putting it in the fridge in a bag of rice to get the moisture to condense, and heating it with a hair dryer to get the moisture to evaporate out, but it hasn’t done too much so far.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The only thing you can do is pull it apart and unhook the battery immediately and dry it with warm air. Don't charged it. Once it's wet it starts corroding immediately especially with power going through it. Clean any corrosion with a qtip and alcohol or a soft brush like a toothbrush. But the issue is that once it's been wet it's likely to cause issues and could stop working at anytime. Repair shops won't work on water damaged phones except to retrieve data.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Noa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 457
