Ir para o conteúdo principal
A edição maior do décimo smartphone topo de linha da Samsung, lançado em fevereiro de 2019. Saiu de fábrica com o Android 9.0 (Pie).
My Phone Is Water Damage
I have water damage s10 plus it's not turning on what is the problem with my phone battery issue lcd issue or anything else?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
If it's water damaged it could be anything. Once it gets wet and has voltage running through it, it will start to corrode on the connections immediately. You will have to take the phone apart and clean it up and find any shorts and probably a new screen and you will most likely still have issues with the phone. Most repair shops won't work on phones that are water damaged except to extract data because of all of the problems and all of the future problems.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
rashdiziad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 2,327
