Ir para o conteúdo principal
O Nokia 6030 é um celular GSM de banda dupla com alternância automática entre frequências.
How to repair power button?
The Nokia 6030 has its power button on its top as part of the back casing.
I have noticed that the button does seem to work/respond very well anymore on a unit. My impression is that its alignment with the contact it presses into may not be correct. Perhaps the button is somewhat warped.
It looks like the button may be removable, but I have not been able to remove the button with decent pressure from under where it appears to be attached.
How can one repair the power button? Can the repair be done without replacement of the back casing itself?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Nokia 6030c-2 many bottom not working problem
Esta resposta foi útil?
Pontuação 0
1 comentário:
Nokia mobile 6030c-2 many boton not working problem
por
Adicionar a sua resposta
User5 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 371
