How do I fix a TV where the sound works but the screen is black?
Model: LG 65" Class 4K Ultra HD LED Smart TV - 65UH615A - 350124
When I power on the tv, I can get sound and change channels but I am not able to see anything on the screen. This is the case for my HDMI tv channels as well as other HDMI ports (e.g., apple tv).
Esta é uma boa pergunta?
2 comentários
Hi
Can you view the menu screens OK?
Have you tried other input types i.e. Component video or Composite video or even antenna input?
Try shining a torch at an angle close to the screen when the TV is on and there is audio, to check if there are any images at all. They will be very faint so trying this in a darkened room may help.
If so you have a backlight problem, which could be the power board, the backlights or perhaps the mainboard not telling the power board to turn the backlights on
por jayeff
Appreciate the responses. Here are my answers. I’ve also uploaded a video that may help: https://youtu.be/DuUTdteK5Y0
@Jayeff
* I cannot view the menu screen.
* I have tried multiple inputs but same issue.
* Tried shining a flash light in a dark room with lights out but not able to see anything.
@deadcapacitors
* I do not know what small holes you’re referencing. Tried to peak through everything but couldn’t see anything. When I turn the tv on, it goes to a gray screen.
Appreciate both of your help. Really hoping I can figure this out and get it fixed. What type of company would be the best in San Francisco to call or should I be able to fix it myself?
por Justin Herzig
