Ir para o conteúdo principal
O OnePlus 7T é um smartphone Android da OnePlus. Ele foi lançado em outubro de 2019.
Water inside charging port
A few drops of water got inside my phone's charging port and unknowingly I charged my phone after that but nothing happened , no burn marks and even my warp charge is performing great but should I be worried about it being damaged in future?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Treating liquid damage is like treating a stain on your favorite shirt in that you want to address it immediately. If you were able to get the water out of the port fast enough using methods such as compressed air or some rubbing alcohol and a toothbrush, you should be ok. On some android phones today, they can detect water in the port and even notify you. My note 8 has this feature. I’ve gotten water in my port a few times and as a repair shop owner and technician, I’m confident my port is fine.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Is there any chance that the charging cable might push the water droplets inside of the phone?
por Compartilhar
@veixyb it could be a possibility but if it was a little splash of liquid you should be fine
por Compartilhar
Adicionar a sua resposta
Veixy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 1,822
