Ir para o conteúdo principal
Os modelos BMW X5 2000-2006 foram a primeira geração (E53) dos crossovers esportivos da BMW. O X5 foi lançado inicialmente em 1999 para o ano-modelo 2000 e apresentava tração integral com transmissão automática ou manual.
Car stuck in limp mode..accelerator is not responding..changed accele.
Stuck in limp mode..accelerator does nothing..changed accelerator but same thing
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You need to find the fault codes and that will give you a idea what you need to physically check. So this has a throttle sensor and you changed it and it didn't do anything. You need to test each sensor for input voltage and output voltage from the sensor to the ecm/pcm. You could have a mouse that chewed a wire. You need to find the flow chart for the trouble codes and follow them. Repairing automotive computer systems is not easy. It takes a lot of education and skill and thousands of dollars of equipment. My advice is if you aren't a trained automotive technician who specializes in diagnostic repair and has spent thousands of dollars on equipment, I would recommend taking it to a repair shop. You will probably pay more money throwing parts at it and not fixing it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
smokinsmitty.1972 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 401
