Ir para o conteúdo principal
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
Had power outage, when power came back on, unit will not turn back on
When Power was restored, the LCD screen is blank and the unit will not turn back on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @surferj7 ,
The outage may have damaged the circuit board.
Open the machine and inspect the board for any obvious damage to the components.
Here’s the ifixit Keurig 2.0-400 Circuit Board Replacement guide which may help.
Here’s an enlarged image taken from the guide which shows what to initially check that they are OK.
(click on image to enlarge for better viewing)
If you spot something or if you’re not quite sure post some close up images of the board. Here’s how to do this Adicionar imagens a uma pergunta já existente
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Keurig 2.0-400 Circuit Board
Guia
Difícil
30 - 35 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mike Jackson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 351
