Ir para o conteúdo principal
O ASUS Q536F foi lançado em maio de 2019. Um PC 2 em 1, opção econômica em comparação com os concorrentes, tanto para uso diário quanto para jogos.
Back Pannel Won't Come Off
There is something holding my pack pannel on and I can't figure out how to take it off. From the outside it looks like a circle made of the same material as the panel. I can pry it open and look inside and it seems to be a screw. I can't move it as there is nowhere to place the screwdriver. It may be on the otherside underneath a keycap but from what it looks like it doesn't like up with any keys. Pressing down on it does nothing, I can't rotate the back pannel off either. Anyone know what this is and how to get it off?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
5 comentários
Hi,
Did you look under the “feet” to see if there are any screws there, holding the cover on?
por
I can pry the whole thing off, its just that part in the middle that is holding onto it.
por
what screwdriver did you use to open the screws?
por
Maybe the screw is under the keyboard. Take out keyboard and have a look.
por
https://www.youtube.com/watch?v=WW30dcvq... this model should be the same frame. if it is holding in a obviously no bottom screw area you need to pop the plastic off from the top the keyboard and remove those screws to expose the screws that you need to get at
por
Adicionar um comentário
1 resposta
Solução escolhida
This is most likely a cover hiding a screw in the middle of a back panel. You can use a very small flathead screwdriver (e.g. flathead 1) to pry off the screw cover and get access to the screw head.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Braxton Biggers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 1,105
