Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Can I replace mod 2015 with Mid 2014 screen?
I dropped my MacBook Pro 15 mid 2015 laptop and the screen broke.
So I’ve a MacBook 15 mid 2014 screen and wondering if I can use the screen on my mid 2015 laptop, are the two models are compatible to switch screens?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Sadly, Apple altered things once again! The 2015 display is different than the 2014!
You’ll need to fork over the cash for the correct display: 2015 15” MacBook Pro Retina Display Assembly Apple P/N 661-02532
Sorry ;-{
The bad news is these are getting hard to find as a full assembly!
You’ll need to get the raw LCD panel and very carefully replace the panel heres a view on what it will take here: MacBook Pro Retina Display Teardown
Esta resposta foi útil?
Pontuação 1
I am in opposite situation. having 2014-mid laptop with 2015 screen...any chance to switch,,
Pontuação 0
1 comentário:
D Field, go read @danj's response to the original question and you'll have your answer.
There, wasn't that better than me saying, "RTFM", or "per my last email"?
por
Adicionar a sua resposta
psokmail será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 2,239
