Ir para o conteúdo principal
Câmera DSLR digital Nikon D600 com sensor CMOS full-frame de 24,3 MP
Repairing a mounting ring
Can repairing a mounting ring on a Nikon D600 be a diy project?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
ccbrown12 check on here Teardown da Nikon D600 I cannot see any reason why this could not be done by a DIY’er. Now the issue is, why you want to change it. A lot of times the ring gets damaged when the camera falls on the lens etc. Sadly enough, this will commonly “break the body part where the mounting ring screws to. That would be a different repair altogether since it would require to at least replace Front Body and in some case the Mirror Box and the reflex mirror.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ccbrown12 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 499
