Ir para o conteúdo principal
O Wonderboom é um alto-falante portátil Bluetooth da Ultimate Ears. Lançado em 2017. Número do modelo: 984-000839.
Is it possible to replace the battery?
The speaker fell out of my bag as I was going into mye car, and I accidentally drove over it. Some og the casing were broken but it would still connect to my phone and I could even play songs on it. But I was worried the battery could have been damaged, and after I took everything apart, the battery is clearly damaged. The weird thing is that all the other components were fine. Is it possible to get a replacement battery?
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Here’s one possibly 3 line 3.8v lithium ion rechargeable battery You will need to check the lines as your battery appears to have two lines for the positive and negative pads.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Per Henrik Mork Viken será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 2,553
