Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Screen Flickering Issue on Dedicated GPU
My laptop screen will randomly flicker when the dedicated GPU is used. Does anyone know what could be the issue?
Here’s an exact same issue that’s happening that I’ve taken from YouTube.
https://www.youtube.com/watch?time_conti...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Not very sure, but if i recall correctly, these models are plagued with GPU issues. A ‘fix’ would be to disable the discrete gpu and only use the intel internal graphics. (You will lose performance, but flickering should be gone
Here’s a link: https://apple.stackexchange.com/question...
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for the comment! I currently use gSwitch to run integrated at all time and it seems to have fixed the issue. But sometimes I use dedicated and the flickering is annoying.
por
Adicionar a sua resposta
Brandon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 264
