Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Replacing Hard Drive with SSD
I want to replace the drive with the 1TB SSD from this site. The page for the SSD says it requires a SATA III controller. How do I confirm if I already have that? Or is that something I can install? Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
That MacBook already has a SATA 3 controller, that is embedded with the logic board on a chip called the PCH (Platform Controller Hub or you could say chipset).
I assume you are referring to this SATA SSD right? If yes you can install that and reinstall MacOS (additionally do a time machine backup to do transfer) and you’re all set.
OWC Aura Pro 6G SSD
MacBook Pro 15" Retina Display Mid 2012 SSD Replacement
Imagem de Replace or upgrade the SSD in a 13" or 15" MacBook Pro with Retina Display from 2012 or Early 2013.
Produto
OWC Aura Pro 6G SSD
$49.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes! Thanks!
por
Adicionar a sua resposta
Josh Rushing será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 69
