Why is my 2 year old microwave throwing a breaker? JVM3160RFASS
2 yr old microwave throws a breaker? Why?
Esta é uma boa pergunta?
Hi Julia, any abnormalities when using before it happened ?
https://www.sos-parts.com/microwave-trip...
There are some possible causes why this will happens, e.g. faulty door switch, faulty magnetron .... bad capacitor, HV diode etc ... do note that working inside microwave oven, involves with high voltages, if unsure, consult someone who know about this. it can be lethal if you are unsure what to do.
Esta resposta foi útil?
No prior problems. However, it started with throwing breaker ever once in a while, then every time.
My guess is you have a short in the system. The problem is microwaves usually aren't that expensive to replace and they aren't worth fixing unless you have a higher built in one.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 73
1 comentário
Thank you! Just what my husband said!
por julia
