Water Not Running in Machine - Makes a Humming Sound RESOLVED
We have replaced the inlet valves, the water modulator, the distribution motor, and the pump in the bottom. All to no avail it clicks then just hums no water runs in at all. We are at a loss. There is nothing wrong w the plug or water from the house. We had been getting the F21 error before we replaced all this. Also we cleaned the drain thing in the bottom. I have not seen anyone w this problem.
Update (05/24/2020)
Well folks turns out AFTER replacing our washer with another one we found out that the cold water spigot had quit working after untold numbers of years. The thing to consider is how
Esta é uma boa pergunta?
4 comentários
Hi @gdawson57 ,
Does this happen on both hot and cold wash cycles at least for the initial fill?
Have you checked the filter in the water inlet hoses to make sure that they're not blocked with grit, you didn't say?
You don't state the model number but usually the filter is located in the end of the hose fitting that connects to the machine but sometimes it is in the machine at the same connection point
por jayeff
Thanks for your reply.. Yes we've checked the filters. And yes it does that w both Hot and Cold water. It is a Kenmore Elite Quiet Pak 4. H3t
por Gwyn Dawson
The Model of my Machine is Kenmore Elite Quiet Pak 4 110.46742 702. I looked up the part on Sears Direct and for my model it is not listed and we saw a video where a guy replaced one. We looked at our machine and there does not appear to have that part. It is nowhere visible. According to the video the Water Level Pressure Switch wouldn't stop water from flowing altogether.
And you were right I stated the incorrect name of the Flow Meter. That was also replaced.
por Gwyn Dawson
Guessing I'll be calling in a Repair person.
por Gwyn Dawson
