Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Perguntas Visualizar todos
How to tell if battery is dead
I am trying to fix my 1st gen iPhone that I just bought as non working. It seems that the battery is bad, but I want to make sure that it's really the problem before ordering one. Whenever I tried to restore it in itunes or 3utools, it always tried to reboot and just turned the screen off every time. Sometimes, the backlight would turn off and a ghost of the screen could be seen for a few seconds. I can get the phone in DFU and recovery mode no problem, but as soon as I unplug it, it shuts off immediately. With the latest itunes I would get error 1604 and 1603. Is this likely the battery or is the dock connector or motherboard bad? I tried to download older itunes versions, but even on vista or Windows 7 machines I had no luck showing the “iphone software update server could not be contacted”.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Does it work O.K. with the power supply/charger plugged in?
If yes then replace the battery:
iPhone 1st Generation Battery Replacement
If not them you have a more serious problem, I would imagine.
Esta resposta foi útil?
Pontuação 1
1 comentário:
The phone can get it DFU and recovery mode, but I can't boot up the phone or properly restore it, should I try changing the battery or is it a lost cause?
por
Itunes is not longer supported by Apple, maybe that is why you got that error. Now Apple application is named Music App.
Pontuação 0
Adicionar a sua resposta
David Gagnon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 88
