Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
20 Perguntas Visualizar todos
Little/No Trackpad Feedback After Small Spill
I have a friend who spilled a small amount of sugary beverage onto the keyboard of her 2017 MBAir. There are only three keys that are sticky that I’m going to clean with 99% alcohol. However, the track pad is also not clicking as it should. I’ve never run into this problem and I don’t know if it’s related to the logic board, a cable, or the trackpad itself. You have to really force press the trackpad in order for inputs to register.
I’m going to open it up and clean any noticeable residue but wants to know if there is a common solution to this.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@mayer @danj any suggestions would be greatly appreciated
por
Adicionar um comentário
1 resposta
Solução escolhida
Here’s the needed guide to take the touchpad out MacBook Air 13" Early 2015 Trackpad Replacement
You’ll need to clean the case edge where the touchpad fits into so the touchpad physically depresses on the bottom edge to enable the click switch. As far as tracking that implies the pads sensor sandwich got damaged, that means you’ll need a new touchpad unit MacBook Air 13" (Mid 2013-2017) Trackpad
Imagem de Replace a scratched or malfunctioning trackpad compatible with a Mid 2013 to 2017 MacBook Air 13" A1466 model laptop.
Produto
$49.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yep, it was just stuck on the edges. Thanks!
por
Adicionar a sua resposta
Alex Robinson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 88
