Ir para o conteúdo principal
Uma unidade de disco óptico externa da Apple, essencialmente um rebranding da MacBook Air SuperDrive.
Can broken cable be fixed?
Cable has cracked at the mount point on the drive and drive is no longer working - is not getting power. Can I open the drive up & get access? Is the cable replaceable?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It will take some doing! Follow this guide Substituição da unidade de disco óptico do Apple USB SuperDrive once you have it opened up you should be able to de-solder the cable.
Now the fun begins! Using a 3D CAD program design a new strain relief block. Start by making an exact match to Apples part. Create a threaded end over the cable so you can thread on a threaded collar to hold the pieces together. Now split it in half (Top/Bottom) making room for the replacement cable you’ll want to use, and lastly create the collar piece. Find a friend or someone who can 3D print the parts (hopefully you have no errors) You may need to tweak the design a few times.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I wish I had the skills to do this!
por
Adicionar a sua resposta
c.schrey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 626
