vintage fan .the Isolation is stuck ,can it be fixed?
the Isolation is stuck,the knob is off and it keeps trying to do it and “stuttering” in it attempt .if I use it will it burn out the motor ? and can it be fixed ?
Esta é uma boa pergunta?
Hi @heyscripty
Check if you can manually position the oscillation control and if the oscillation gear is OK and see if this resolves the problem.
Here’s the ifixit Holmes Blizzard Fan Oscillation Gear Replacement guide that may be of some help.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 169
