Ir para o conteúdo principal
Repair information on products used in health and personal care. Fixes tend to be simple and require only common tools.
393 Perguntas Visualizar todos
My Braun 7898cc is not charging , no power.
Purchased a Braun 7898cc now a while ago and used it only like three times.Wanted to use it today so i tried turning it on but no response.Tought it needded a charge so i plugged it in and no response.Could the charger be the problem?Pls help.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
How long did you leave the charger plugged into the shaver?
You said “Purchased a Braun 7898cc now a while ago and used it only like three times.” Depending on how long ago this was and whether or not you charged the batteries in between times, the batteries in the shaver may have become depleted beyond recovery.
Try leaving the charger in for 1-2 hours and see if the batteries are “kick started” back into life and start charging again.
If it eventually shows that it is charging, allow the shaver batteries to fully charge before trying to use the shaver.
If it does start remember to charge the batteries once in a while, maybe every week, even if you’re not using the shaver to prevent this from happening again.
If the shaver doesn’t start to charge at all, according to the service manual there is a 2 year manufacturer’s warranty on the shaver.
If the shaver is not that old, contact the Braun customer service centre in your location as per the directions in the warranty link above.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Thank you for replying i will try that and see fi it works and no i havent charged it between using it.
por
Even the clean and renew system isnt turning on.Could that mean that it is the chargers fault?
por
@sour cookie
It could be.
According to the service manual the charger's output voltage specification should be printed on the charger itself.
If you have a DMM (digital multimeter) you could measure the charger's output to see if it is working or not.
If you haven't got a DMM or even if you have if the shaver/charger is less than 2 years old get it replaced under warranty. Don't try to fix it yourself. That's what warranties are for.
por
Thank you for replying and helping me.
por
Adicionar a sua resposta
sour cookie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 23
Últimos 30 dias: 108
Duração total: 12,707
