Ir para o conteúdo principal
Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
64 Perguntas Visualizar todos
Nikon D3400 partially black screen - after being dropped
Someone dropped my camera (Nikon D3400) and it landed bottom first. Thankfully, the lens cap was still on and there was no damage to the lens itself. However, the bottom was slightly chipped and now I noticed that when I take a photo approximately the top quarter of the screen comes out black and the rest of the image is fine. When I look through the viewfinder everything looks normal, but if I switch to live view or take a photo a small part of the screen is black.
Any ideas on what is wrong/ an estimate to fixing this problem? Any help would be appreciated.
Sorry for the lengthy post, just wanted to provide all the details! Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @sumzzz,
When you say “…..or take a photo a small part of the screen is black.” do the photos show a complete picture when downloaded and viewed on a computer?
If the downloaded images are OK then most probably there is a problem with the camera’s LCD screen. Either it is faulty or it has a loose flex cable connection due to the fall.
Here’s a video that shows how to replace the LCD screen in your camera. This should allow you to check the cable connection first and if it appears to be OK then to replace the LCD screen (supplier example only to show what it looks like and the cost - there may be other suppliers that suit you better. Just search for Nikon D3400 LCD screen to get results).
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi @jayeff,
Yes the complete picture shows when I download the images. Thank you so much for your help!! I really appreciate it!
por
Adicionar a sua resposta
sumzz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 974
