Ir para o conteúdo principal
Is G5 model A1076 the logicboard the same as the model A1058?
My G5 can't boot and the led 3 in logic board can't light,so I think maybe there has some problem with my logic board,and i have another working G5 model A1058 17 inch,i open it and found the logic board is the same,but i not sure,so my question is can i put the 17 inch the logic board replace the 20 inch logicboard,thanks helping me
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Does it mean every mac the display the CPU and logic board is connect with each other?if i put mac mini the whole thing in imac g5?can I light the display?
por
Adicionar um comentário
2 respostas
Solução escolhida
The 20" A1076 uses a 820-1747 board whereas the A1058 uses a 820-1540 board. The boards are not identical. Compare the connectors i.e. J7600 etc which is not located where you would expect it etc. It is a different board. The Mac Mini uses a different technology altogether and it will not connect to your display etc.
Esta resposta foi útil?
Pontuação 1
1 comentário:
thanks,now i clearly know
por
Pergunta mais útil
These logic boards are not interchangeable.
Pontuação 2
1 comentário:
Chould u tell me why,and if i replaced,what bad things will happen?thanks a lot
por
Adicionar a sua resposta
Johson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 58
