Ir para o conteúdo principal
Device repair guides for the Ricoh Theta S, a 360-degree digital camera capable of taking HD pictures and videos. It can be identified by model number 910720.
3 Perguntas Visualizar todos
When power on flashes once in blue, and twice in red, then shuts down
It fell down from one meter height…
After that, when powering on it only flashes once in blue, and twice in red, then shuts down.
What could be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi, ,
Falling down from a 1 metre height is not good, especially if it landed on a hard surface.
Since it is not staying powered on the only thing that you can do at the moment is to open the device and check for any obvious damage such as broken or loose connections or even components that may have been jarred loose by the fall.
Here’s the ifixit Ricoh Theta S Repair guide that may be of some help
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
david será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 208
