Ir para o conteúdo principal
Guias de reparo e resolução de problemas para o notebook gamer Asus Republic of Gamers Strix de 15,6" com o número de modelo GL503VM-B17N13.
Laptop Keyboard not working
One day, I was going to go and play csgo on my laptop and my keyboard is no longer working, but is lit up. I really need help.
edit: I just a notification/answer and I tried it but my keyboards name wouldn’t pop up.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
did you fix it?
i changed the keyboard it was a mess but still not working I think its something in the mother board, =(
por
Adicionar um comentário
2 respostas
Pergunta mais útil
If your Asus keyboard driver is faulty, the Asus laptop keyboard not responding issue could crop up. You could uninstall it first and then reinstall it.
Step 1. Right-click Start and click Device Manager.
Step 2. Locate Keyboard and expand it.
Step 3. Right-click on the keyboard name and click Uninstall.
Step 4. Reboot your PC and Windows will reinstall the keyboard driver for you automatically.
If the above method works for nothing, otherwise check out post Methods to Fix Laptop Keyboard Not Working.
Make sure try one by one until it is working.
Esta resposta foi útil?
Pontuação 1
After doing so much on the laptop via onscreen keyboard I actually took keyboard off the laptop. Saw that the connector strip had come loose. There is one for the mouse pad bit too. I had black screen of death. Had to open it. Blew out fluff. Got it oing but keboard didn't work afterwards as I'd disconnected the strip when I opened it. Connected again and now working
Pontuação 0
Adicionar a sua resposta
Savageraging Gamer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 11,287
