Restore Dell Dimension E521
How do you restore or repair a dead Dell Dimension E521?
Esta é uma boa pergunta?
Hi @tear_fall12
What really happened?
cannot power on or boot up well?
IIRC this Dell series, notorious for bad bloated capacitors in the mainboard.
http://iamnutsandsoami.blogspot.com/2012...
Inspect the board and the power supply unit on that.
Esta resposta foi útil?
It's *usually* the power supply. Any ATX unit will suffice on these, but you need to watch the cable length by the hard drives. The motherboards are usually solid.
I appreciate your help. I will have to find some times to try it out.
Thank you very much
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 218
1 comentário
What is wrong withit?
por imjusthecoolest
