Vertical lines on left half of screen
A couple of days ago lines appeared on my Hitachi 48” tv screen (48hk6t74u). The lines are on the left hand side (as I sit facing the tv). There is one thick black line next to coloured thin lines from top to bottom of the screen. It is only a couple of inches wide in total. After looking a videos online, the general consensus was that it was the display ribbons or the T-Con board. I swapped the ribbons over to check if this was the problem and the issue was still in the same place. I then replaced the T-con board with a new one. Unfortunately, this has not fixed the problem and the lines are still there. When I take the ribbons out, and turn the tv on, the screen is completely blue. Then when I replace them, the picture is fine apart from the same lines on the left half of the screen. Does anyone know what the issue might be and is it fixable?
Esta é uma boa pergunta?
